remove selection from select_multiple in calculation
762
03-14-2018 08:40 AM
BrentKinal1
Occasional Contributor III
I have a select multiple question that has an option called "Not Listed" that if selected exposes a text question to enter the not listed value. I would like to combine the responses from the select multiple field (minus "Not Listed") and the text field in to a new field. I have the calculation set to combine the two fields, however I would like to clean things up a bit and remove the "Not Listed" response from the string, is there a way to select everything but from a text string?
I have tried the not() statement but just get the response "true" in my calculation.
Thanks!
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Brent,
Right now this is somewhat difficult to do, as a select_multiple does not guarantee order.  That being said, we are trialing a feature in the Early Adopter (beta) community that might meet your needs.
BrentKinal1
Thanks James!
I couldn't figure out the exact feature in the early adopter program to handle this, what feature should I be looking for?
In this current case there aren't a whole lot of values in the select multiple question, so I could just link a bunch of if(selected$(select_multipleField), 'valueName', 'valueLabel ', '') + ... statements together. I am hoping down the road to find a more eloquent approach esp for longer select multiple lists.
JamesTedrick
Hi Brent,
I was referring to the custom JavaScript functions - one of the applications for this is custom text processing.  You could easily to split the choices, remove a value and reassemble them.
CarolineRose
New Contributor III
My strategy for removing underscores from a select_multiple response may also offer you some ideas for cleaning up your list:
https://community.esri.com/thread/197470-can-you-calculate-a-hidden-field-removing-the-underscore-fr...
Essentially, you create a hidden question for each option that populates with your desired text string, then create a text question that concatenates all of the corrected text strings using "join". It can be that simple if you don't care about a trailing comma-space (or whatever your separator is). You can get into more logic if you care to eliminate trailing separators.
I can elaborate further if you need.
