Remove Choice From Survey after Selected - Survey123
1136
02-07-2022 08:44 AM
SeanGavlas
I have a list of 15 sample IDs that are in a select_one list and I'd like to remove each ID from the select_one drop-down after it has been selected and submitted so the next user does not select the same ID.  How can I go about this?
Sean G.
Katie_Clark
MVP Regular Contributor
So, I'm honestly not completely sure, but is this what the "allow_choice_duplicates" column is for in the Settings tab of the XLS form?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Iron_Mark
 I am currently trying to achieve this.
Does anybody have any suggestion? Is it possible to remove a choice from the choice list if this is selected in the same/another survey?
