Relevance based on phone number/text field with numeric appearance
416
10-31-2021 07:14 AM
newwollyka
New Contributor III
I have a text field with a numeric appearance. The text field has a mask input to format it as a phone number in my country (XX-XXXXXX).
If there is no phone number, the surveyor should enter 99-999999. Then there are several questions related to that question and should only be relevant when the phone number isn't 99-999999.
I tried using != eg. ${phone}!='99999999' but it is not working. I tried using the functions contains() but same results.
newwollyka
New Contributor III
One solution I found is to create a hidden calculate field with the expression:
if(contains(${phone},'99-999999') ,1,0) and then put in the relevance column for the questions the following: ${phone_check}=0 and it worked
newwollyka
New Contributor III
