Regular expression for a person's height
615
06-11-2020 12:58 PM
ryanEvanczyk
I used an online regex checker and I've got what I want to work, but it won't work when I put it into my form via survey 123 connect.
regex(.,'^(\d)\'(([0]\d)|([01][01])|(\d))\"$')
I've had a similar issue before and simply retyping it vs copy/paste solved the issue, but not this time.
I'd like the examples 0'11", 9'11", and 9'1" to all be valid.
Thanks for the help,
RyanE
DougBrowning
You could use 2 fields then you could check for like 4-6 on feet and 0-12 in inches as well.  Can then combine them after in a 3rd field.
Just an idea.
ahargreaves_FW
I too am struggling with this. I'm using:
regex(.,'^([1-8]')?\s?([1-9]|1[01])$')
@IsmaelChivite , @JamesTedrick  any insight?
