Radio button for my template and I cant get back image
627
02-03-2019 12:39 AM
RawandDizayee
Dear All,
How i can get radio button for my template i really needed for my survey template. anyone could help me please i really appreciate it. the attached below show what i mean.
plus am using enterprise portal i cant retrieve my images to my template, not supported for enterprise portal so far ?
thank you in advance
JamesTedrick
Esri Esteemed Contributor
Hi Rawand,
The selected option described in the "Multiple Choice" section of Feature report templates—Survey123 for ArcGIS | ArcGIS also works on single choice questions and should meet the requirement you are describing.
The inability to access images is a known limitation for ArcGIS Enterprise installations - the data model in ArcGIS Enterprise cannot yet store information to identify which attachment goes with a particular question.
RawandDizayee
Dear James,
I am really happy to see your replying emails . regarding "Multiple Choice" actually i wanna single selected(circle option)
with the showing rest of options in the template, i really tried multiple times unfortunately didn't get any result to get the selected option pattern like i clarified in my attachment, could you help me to write an expression works as same as the pattern i mentioned.
for the second part of my question after we collected data from field we have to convert the records to hard-copy(PDF) and send it to official authorities, do you have any guess which help us for this procedure ?? because Reporting in survey123 website still Beta i think we cant rely on it.
regards,
JamesTedrick
Hi Rawand,
Currently, there are not display options to change the look of the select questions - I've taken that back as a potential enhancement.  We do plan to add PDF output in the future; currently, you would need to do that as an additional step (a print to pdf driver might the most efficient way to handle that).
