"An upgrade is required for this survey" in Survey123 Connect
3480
6
06-14-2016 09:06 PM
TravisKiel
I am getting this error message in my Survey123 Connect program yet I am running 1.4.30.  I am however running a free 60 day trial of it and wondering if that is the issue?  Any help would be great.
I can still create and use reports but nothing actually goes to my online Survey123 for ArcGIS, where I can look at the data.  Gives me a message that no records have been updated.
IsmaelChivite
Esri Notable Contributor
Hi Travis. You can ignore  the upgrade button message. It is a bug which will be addressed in our next update  (planned to be made available next week).
Before you can see records in your Survey at http://survey123.arcgis.com, you will need to submit data to it. Try the following:
* First publish your Survey from Survey123 Connect for ArcGIS.
* Download the Survey123 app from the Google Play or iTunes store
* Login with the same credentials you used to publish the Survey
* Download your Survey into your phone
* Start collecting data and submit the data. Submit a couple of times to make it more interesting.
* Then go back to http://survey123.arcgis.com, refresh the Survey Gallery and access the Data and Analyze tabs to see your records.
You may want to make some tweaks to your Survey. You can publish again your Survey after making the changes from Connect. Then you will need  to download the Survey again into your phone to refresh the changes.
Once you are  happy with the Survey, you will want to create a New Group (or use an existing one) in ArcGIS Online. Then you will want to invite colleagues into that Group and  Share  your Survey with that Group from survey123.arcgis.com using the Collaborate tab.
TravisKiel
Yes I have done all that and I still see no reports going to my http://survey123.arcgis.com site.
When I go there, and click on the "Data" button I get this
And when I click on the Form I get this screen ...  the computer just grinds away and comes up with nothing.
Travis
IsmaelChivite
Hi Travis Kiel​.  Would you mind doing the following:
1- Download and install the latest version of Survey123 Connect for ArcGIS. We just updated it. You will not lose any work you may already have.
2- In your web browser, make sure  you clean up your browser cache and try again at https://survey123.arcgis.com   Try https instead of http
If the problem is not resolved please let  us know.
Ismael
TravisKiel
I have yet to download the latest version but the https vs http has worked.
Thanks..problem sovled.
Unrelated now...but can you edit or change a survey that has been uploaded?
Travis
IsmaelChivite
You can definitively change surveys that have been uploaded.
Please try with the latest version of Connect (1.5.x).
TravisKiel
1.5.32 uploaded and it also works.
Thanks
Travis
