Questions showing twice in form view
668
05-28-2021 08:23 AM
KarlaJohnson
When I look at survey information which has been collected some of the questions are showing twice in the form view.  The data looks fine in the table and the survey worked correctly.
by Anonymous User
Not applicable
Hi @KarlaJohnson,
Can you please provide more information, such as screenshots of where you are seeing the data twice in form view? Also are you using the web app and field app for data collection, and what do you mean by form view?
Regards,
Phil.
KarlaJohnson
Hi Phil,
I am using both the web app and field app.  Attached is a screenshot of the record when I open the data through my survey and the form view printout.  As you can see some of the field show up twice. In the form view.
JodyZhengLiu
Hi @KarlaJohnson ,
Is it possible to share the xlsx file (you can send it to my email: zliu@esri.com)? Does the question has a special bind::esri:fieldTye setting?
Jody Zheng Liu
KarlaJohnson
This survey was not created through Survey 123 Connect.
