I have a survey where I use a custom JavaScript function to fetch watershed feature service data from a geopoint input and I can't seem to correctly parse the json response object for the watershed geometry in the XLS form. Specifically, I am after the 'SHAPE.AREA' attribute which is inconveniently named with a period (SHAPE.AREA) I was expecting the JavaScript syntax attributes["SHAPE.AREA"] to work in my pulldata function but it does not. Can anyone advise?
Ouch!
Could you extract the value using JS syntax within your function?
