@pulldata in Survey123 stopped working
286
10-01-2025 03:45 AM
Aure_Jardines
Hi there,
I can´t figure out the issue.
My surveys were working fine until mid-August, but since then they haven’t been working properly. The problem is that the field which should be automatically filled by the pulldata function is not being populated.
i'm using pulldata function on calculation field, like this
pulldata("@layer", "getValue", "attributes.nameFieldFeature",'https://services5.arcgis.com/as5dr6ZhyY4GBjjt/arcgis/rest/services/NAME/FeatureServer/1', concat("key=", ${KEY}))
I would greatly appreciate any help
2 Solutions
Neal_t_k
Try taking the concat() out and put it in a helper questions.
${clause} = concat("key=", ${KEY})
pulldata("@layer", "getValue", "attributes.nameFieldFeature",'https://services5.arcgis.com/as5dr6ZhyY4GBjjt/arcgis/rest/services/NAME/FeatureServer/1', ${clause})
sometimes the pulldata() don't like calcs inside the function.
Aure_Jardines
Hi @Neal_t_k ,
thanks a lot!.  Finally, it worked by removing the CONCAT from @pulldata and adding single quotes at the end of the concat in those coming from text fields.
Neal_t_k
Aure_Jardines
Hi @Neal_t_k ,
