Pulldata: Get geopoint from another layer into a new survey
597
11-13-2023 05:51 PM
Teresa_Blader
I'm kinda new to pullData. How do I pull a point location from another layer for geopoint?
I'm using an autocomplete search("...") in the appearance column of a select one to dynamically populate a choice list from a name field in another point layer. Based on that selection, I'd like to pull the location of that point's location. I imagine it would include a simple filter based on that, but I'm really not sure of the syntax of how to get a geopoint in general. I tried reading through the help docs, but wasn't really finding what I think I needed. Thanks in advance!!
Teresa Blader
Olmsted County GIS Specialist
ezirhli
Hi @Teresa_Blader,
The appropriate esri blog post for your workflow. I think you should try it.
Survey123 Tricks of the Trade: Creating a GeoList (Survey123 Connect)
Enjoy your work
ezirhli
Hi @Teresa_Blader,
Enjoy your work
Teresa_Blader
Wow! Thank you, that is exactly what I need and couldn't find myself! Thanks!!
Teresa Blader
ezirhli
You're welcome!!!
