public survey in browser isn't showing correct on iPhone
296
04-20-2023 10:47 PM
Survey123Jedi
This table isn't showing correctly on the iPhone.
Survey123 Connect was published, and the link/QR Code is used to see the browser.
But the iPhone doesn't show the text correctly.
This is my first time using the browser for a public survey, so I'm in new territory.
Thanks for your help.
RamaniGanason
Hello,
I tested this using my Chrome and it seems like appearing fine.
The issue could be with safari or other browser. If table would be a problem, I can suggest for you to use different type input such as "Single select" instead so you won't have issue being rendered incorrectly or text getting chopped.
Final result :
ChristopherCounsell
MVP Regular Contributor
What version of Survey123 Connect? Another user had display issues with a recent, but not latest version of Survey123 Connect.
More info on the setup? Appearance, question type, any styling?
