problems with coordinate invocation ||| Problemas con la invocación de coordenadas
730
06-30-2022 04:30 AM
JavierCMartínezPrieto
hello everyone,
the problem I have is the following:
I have created a webMap with invocations (button created in the popup window), i.e. it is used from FieldMaps.
When using any of the buttons from the FielMaps it works perfect and brings me the information I need.
and it shows the information in the survey
also this location can be used in other fields of the survey and it works fine as long as it is a point but when it is a line it stops working.
point:
but when it is a line, although it seems to work when this section is opened....
I am located in London...
the way i have done this calculation, has been as follows
this work fine
but this does not work
Does anyone know why it doesn't work or what would be the way to make it work?
thanks in advance to all of you who participate.
greetings
Javier C. Martinez Prieto
