I want to add images next to the choices for a select multiple question. The choices are species of plants and I want to add images for faster and easier plant identification. Presently, the images appear only in the computer based survey and, if I add more than one image, the images do not appear with the corresponding choices. Also, if I add more than one image, the images scramble the list appearance of the choices. I also cannot adjust the size of the image that appears. It needs to be reasonably large for users of the application to recognize the plants. I have tried through the settings in the computer application and also by resizing and optimizing the images for web using IrfanView, neither changed a thing.
Thank you for explaining.
Another question, can you also put a if-not in the same line?
Or do you have to make a new "if" rule?
${if show_the_image=="yes"}${}
I tried this but it didn't go well
Hi Gerard,
You would need to have another ${if } statement for the 'no' condition:
${if show_the_image=="yes">[YES IMAGE]${/}${if show_the_image=="no"}[NO IMAGE]${/}
Again, please refer to the template syntax in the documentation - Feature report templates—Survey123 for ArcGIS | Documentation
okay thanks for the info.
