Hi everyone!!
I´m trying to publish in Portal for ArcGIS (v10.5.1 / v10.6), when I publish the survey, it sends me a message about error 500, if i check in Portal for ArcGIS, it´s created a folder and a Feature Service, but the form doesn´t create.
If i publish it in ArcGIS Online everything works fine.
Any idea!!!
Thanks in advance,
Juanjo Pino.
Solved! Go to Solution.
Hi, please see this note: https://community.esri.com/groups/survey123/blog/2017/08/04/survey123-23-update-and-arcgis-enterpris...
Thanks, I´ll check what you sent me.
JJ Pino
Sent from my Samsung Galaxy smartphone.
Hi!
I´ve created a new survey with only text and a geo-ocation, I´ve the same issue when I tried to publish on ArcGIS Enterprise 10.5.1 (federated and hosted).
Best Regards,
JJ Pino
I told with Esri technical support, the problem was the DataStore, DataStore was in Read Only Mode because there wasn´t enough space in hard disk and changed from READ/WRITE Mode to READ Mode. So I deleted some files and folders and change the mode of DataStore (execute the command changedatastoremode readwrite).
THKS,
JJ Pino.
