Print QRCode on Android
175
01-27-2021 09:13 AM
RodrigoNB
Hello everyone,
I am designing a solution to print QRCode tags directly in Android using Survey123 form.
After the form is completed, it is required to submit few attributes to be printed.
Is it possible to create a Survey123 add-in to call a java class passing the attribute values? After that, I checked that all the printing can be handled inside the java class.
Would somebody recommend another solution?
Thank you,
Rodrigo
IsmaelChivite
Esri Frequent Contributor
Survey123 add-ins can work with QML code. I do not think you can invoke your own Java class. Please refer to the documentation on Survey123 add-ins in the Survey123 Early Adopter Community.
Alternatively, you could also generate the QR code using Integromat: https://www.integromat.com/en/integrations/barcode
