Hello,
Creating a survey in Survey123 Connect and I want to prevent the survey from being submitted if the user selects a certain response. For example, the question is "Type of feedback" and the options are "Bug", "Enhancement", "General". If they select "Bug", we have a Note that pops up that tells them to use another survey with a hyperlink. How can we prevent the survey from being submitted (disable Send button) if this response is chosen as well?
Thank you,
Eric
Solved! Go to Solution.
Hello Eric A,
There are a few options that this can be done, but the first that comes to mind is to make the existing note question you have required. I am guessing it is already relevant based on the selection, but if you have anything in the default column that will need to be moved to the Label. Another option would be to add a new note question that is relevant and required and have the label say something along the lines of "This survey cannot be submitted"
Thank you,
Zach
Hello Eric A,
Thank you,
Zach
Thanks Zach! This seemed to work perfectly. I marked the note that comes up (which was set up as relevant) to be a required question, and now the survey cannot be submitted if that note is active (i.e. they choose the response we want them to use a different survey for).
Appreciate it!
-Eric
Hey Eric,
Building on what Zach suggested, it may be possible to create a relevant question that is also required based on the type of feedback. If we were to make this required field hidden, then it wouldn't show up in the survey but it may prevent submission. Just an idea to try!
hidden question
Type of Feedback = BUG
required= yes
I would be interested to know if that worked for you.
-Lynsey
Thank you Lynsey! While I assume this would as well, based on what I tested from Zach's suggestion, I think going the approach he outlined (setting the Note that comes up as required) is a better approach, at least for me, since that wouldn't require an additional field in the schema. Thank you though!
