Prepopulate field with answers from previous questions?
790
03-28-2023 09:10 AM
choenig
Hello. I am trying to have a field prepopulate an answer based on the results of previously asked questions. For example, the user is asked 1) what the date is, 2) which district they are working in, and 3) what plant they observed.
From those answers I would like to have the next question, "Site ID", prepopulate with results from these answers. For example, the Site ID would read: 0913E_TACA7_0323_001; where "0913E" is default text, "TACA7" is the plant code from a previous question, "03" is the District ID from a previous question, "23" is 2-digit year from a previous question, and "001" is the first observation of this plant (this would ideally be the only part the user would need to enter).
Please see attached image of survey form for name and labels.
choenig
Zach,
I think you're right that the concat() function is what I want to use here. However, I'm having some issues with the syntax. Currently I have:
concat('0913E_', ${Plant_Code}, '_', ${District_ID}, format-date(${Date}, '%y'), '_')
which is giving me the output:
0913E__23_
It's not picking up the first two ${question} items, but does seem to like the format-date. Am I missing something?
Thanks!
ZacharySutherby
Hello @choenig
You can use the concat() function in the calculate column to merge the information together. For example your concat() function could look like:
concat("0913E_", ${plant_code}, "_", ${districtid}, format-date(${date}, "%y), "_")
Thank you,
Zach
choenig
Zach,
0913E__23_
Thanks!
ZacharySutherby
Hello @choenig
When you are seeing the 0913E__23_ output does the Plant_Code and District_ID questions have answers in the form?
Thank you,
Zach
choenig
Ok, it's working. In fact, it already was, I just forgot to test it by answering the questions and seeing it populate the concatenation 🙄 🤣 Thanks for your help!
