Power Automate Survey123 Connector Issue
1242
7
05-09-2025 09:54 AM
WilliamW
Hello all,
I have about 10 Power Automate flows that have Survey123 Response triggers, however, I continue to have issues with the flows failing due to having to reauthenticate every so often (it seems about once per month). I have read various articles about this, most of them being a few years old, so I'm hoping there's a fix for this issue. These are important forms that are public-facing, so uptime is critical. I currently have a manual process I perform to go in and create a new connection every 2 weeks, however, it would be nice to not have to do this. Any help on this would be greatly appreciated.
MikeOnzay
Try this Quick Tip: Keeping the ArcGIS Connectors for Power Automate Refresh Token Valid
Mine is scheduled to run every week on Sunday night. I haven't had any issues since I set it up 6 months ago
JBH
I have the same experience. Sometimes I don't realize that the automation has died and I miss some entries. Not sure if it is a Microsoft or Esri issue.
WilliamW
From what I've read in other posts, it's the Survey123 authentication that expires every 2 weeks, but that was also in an article dated in 2022 or 2019, I believe. I would think this would be fixed by now or there would be a workaround. ChatGPT says it's a known limitation with Survey123 connectors specifically tied to token expiration or OAuth refresh token lifetimes.
NickDunchue
I'm just about to try something myself to create a workaround for this. The plan is to create a scheduled flow to get survey results every week, but do nothing with the results. This will use the token and reset the 14 day lockout. Will keep you posted in 14 days!
WilliamW
I will try this as well. Thanks for the idea.
MikeOnzay
WilliamW
Thank you for the tip. I will look into this. It may require remapping a couple hundred fields, but if it means no longer having to refresh all the connectors, this will be worth it.
WilliamW
Thanks again for pointing me to this post. @SeanKMcGinnis confirmed that Survey123 Connectors are no longer supported in Power Automate and everything has been switched over to the ArcGIS Connectors. I will start the remapping process of Survey123 --> ArcGIS Connectors.
Quick Tip: Keeping the ArcGIS Connectors for Power... - Esri Community
