Power Automate connectors keep breaking
244
10-24-2025 08:55 AM
JenniferBorlick
I am using Power Automate to send emails and upload files from several different surveys. I am finding that almost every time I go in to edit any flow, I have to futz around with the connectors. I have two ArcGIS Online accounts. One is the admin account and one is my department account. This doesn't have to do with the reauthentication issue. The flows work fine until I need to edit them and then I get authentication errors all over the place until I either switch which connector I am using, or "switch user" the connection I am using.
(I also have a reset connector script set to run weekly.) At one point I thought it had to do with being logged into AGO with one or other of the accounts, but that doesn't seem to be the case.
Right now I have one survey that looks fine in the edit page,
but when I go back to the details page, it says that there is a problem with my trigger.
I've even created a new trigger and I get the same results.
I now have 4 connectors, all named Survey123 and I don't have one that works consistently.
Any advice would be appreciated.
