Hello all,
Issue: When viewing the Share Results viewer(Overview,Analyze,Data) for Survey123.com as the owner, surveys entered show on the dashboard but only the repeat table show on the Data tab, and thereby, no points on the map.
Background: I built a survey opened and partially populated from a URL with parameters in Collector. X and Y coords are passed in along with a GUID and another field or two. The map is populated from the XY data and is set to read only, so the user doesn't change the location.
After a bunch of "select_" questions, there is a compact, read-only repeat. The repeat count is 1. The repeat contains a read-only Geopoint and hidden fields for Lat and Long using the pulldata function to store the location of the Geopoint. The Geopoint has a "null" esrifieldType binding. The purpose here is to capture the location of the location of the device when the user begins the survey. Also, they can't update the survey.
| begin repeat | startrepeat | Survey Complete | compact | yes | ||||||
| hidden | submit_latitude | Latitude | pulldata("@geopoint", ${capture_location},"y") | |||||||
| hidden | submit_longitude | Longitude | pulldata("@geopoint", ${capture_location},"x") | |||||||
| hidden | accuracy | Accuracy (meters) | pulldata("@geopoint", ${capture_location},"horizontalAccuracy") | |||||||
| geopoint | capture_location | Backup | yes | |||||||
| end repeat | ||||||||||
So when I view the Data tab in the full Survey123 site for the survey, both table tabs show up under the map: the main table (Fertilizer test) and the repeat table (Survey Complete).
When I launch the Share Results dashboard from the Collaborate page, only the "Survey Complete" tab shows the the dashboard shows the correct number of surveys submitted.
It seems that my approach is correct from reading other posts on GeoNet. Is the main table not showing on the Data tab expected functionality, ie. it is outside the norm so the dashboard may not work correctly? Or is there a better way to capture the survey start point? I've attached a dumbed down copy of the Survey which shows the issue.
Thanks in advance!
Jim
Hi Jim,
Thanks a lot for sharing the issue, your post really helps us diagnose the issue.
Before we fix the issue, could you please try using the data page link to share the result?
https://survey123.arcgis.com/surveys/{survey id}/data
I encourage you to contact Esri Support. Our Support team will assign an official bug number for your records. This number can be used to search for and subscribe to the bug on the Esri Support site. If the issue is reported by other customers it will be attached to the same bug report, which helps us assess the impact of the issue and prioritize it accordingly.
Ruth
Hi Jim,
@Anonymous User
We have fixed the BUG-000133407 (A non-administrative member in ArcGIS Online is unable to view the full results of a survey in the Data tab in survey123.arcgis.com from a survey containing repeats when the survey is shared to a group or organization.) which might be the cause of the issue you mentioned.
Could you please help us verify the fix on the Survey123? Please feel free to leave comments here if you still see the issue.
Ruth
Sorry for the late response, we were busy wrapping up the new release. There are a few possible reasons for the behavior:
1. The layer has the visible range set to a specific scale range. Could you please select a point and then try zoom-in and zoom-out to check if the point appears on a different scale?
2. The layer's point symbol is not clear enough
3. The layer does not have a geometry field
If the above is not your case, please click the open in map viewer button and let me know if the point can correctly appear in the map viewer. Another question is whether this happened to all your surveys or just specific one? Does this issue just occur recently?
Ruth
