Pick list from a field in a feature service?
563
17
a month ago
AmyRoust
I'm struggling to interpret Esri's instructions for generating a pick list from a feature service for a select_one question in Survey123 Connect. I'm referencing the Search function.
Here's what I'm getting from the documentation:
In the choices tab, enter the list name (doesn't matter what I call it), the name (must be the field name in the feature service that I want to pull values from), and the label field (doesn't matter what I call it). Here's my config:
Then, in the survey tab, I populate the type as select_one buildingname (with the part after the select_one statement matching the list_name value in the choices tab), the name (with the name of the field in the feature service), the label (does not matter what I put here). Here's my config:
Then, in the same tab, same row, I have to populate the appearance column with the search() function and the correct parameters, which are supposed to be search(tableName, searchType, searchColumn, searchText, filterColumn, filterText). I can tell that tableName is the URL of the service (including the number of the sublayer), but after that, I get hazy. Here's what I have so far:
That syntax does not actually generate a drop-down menu on the survey. If I add the autocomplete parameter, I get a blank drop-down.
Help?
AmyRoust
Mystery solved. This only works with a hosted feature service, and I was using a user-managed service from my Portal.
HannesVogel
It also works with featureservices referencing from an enterprise geodatabase, it is not limited to hosted featureservices.
AmyRoust
@HannesVogel - Esri tech support confirmed today that it does not work with Enterprise user-managed feature services. They logged an enhancement request for me:
Defect #: ENH-000179151
Synopsis : Add non-hosted layer types as an option when using pulldata/dynamic choice lists in ArcGIS Survey123 Connect
HannesVogel
@AmyRoust Ok that's interesting because it works on my side with Survey123 Connect and a non-hosted featureservice in ArcGIS Enterprise. I can provide ESRI Tech support or you maybe more details if anyone wants to see. Just let me know.
AmyRoust
@HannesVogel - what version of Enterprise and S123 Connect? Maybe it doesn't work because we're on Enterprise 11.3. And do you have S123 installed on your Enterprise deployment? I'm using ArcGIS Online.
HannesVogel
We are on ArcGIS Enterprise 11.3 as well, Survey123 Connect is up to date on my machine. S123 is enabled in our ArcGIS Enterprise but I don't have ArcGIS online involved in my setup, this is what confuses me in your answer.
AmyRoust
I bet that's the difference. I tried to deploy S123 in our Enterprise environment, but no one at Esri could figure out how to get it to work on a multi-machine deployment. I kept getting crytpic error messages during the setup process that no one could figure out. I finally gave up and decided to just use S123 in ArcGIS Online. I bet there is a permissions or access issue where ArcGIS Online does not know how to interpret user-managed Enterprise services. Maybe I'll try to deploy S123 in Enterprise when we upgrade to 11.5.
HannesVogel
yes that's the difference - you try to access the featureservice from "outside"/AGOL, and I do everything within ArcGIS Enterprise. Good luck with the next deployment of S123 in ArcGIS Enterprise - I hope it will work for you!
