I am trying to generate a survey from a FS in survey123 --using 123connect--, my survey requires several photos and the signature. After review, a related table is needed.
When I generate all it from AGOL to my survey (top down) to understand the construction of the FC table and relationship, I can see that the composite relationship 1 to M between the FC and the table is GlobalID vs. ParentglobalID. I try to recreate the FC and the table in the relation for my FS but the table does not appear.
Someone has been able to carry out a survey of this type (generated from an FS to have more than one photo and signature)
Hi Pamela,
It looks like the relationship is not properly set - you have it going from GLOBALID to GLOBALID - on the pru08 table you need a field named PARENTGLOBALID to receive the value.
I generate the relationship between FC and the table, through the globalID field for both the Feature Service is generated, then the survey is created in connect123 but when I try to publish it I find an error of:
Hi Pamela,
Can you provide information on the feature class/table schema and relationship class?
Also, in terms of photo storage, Survey123 makes use of the attachments An overview of the Attachments toolset—Help | ArcGIS Desktop - you do not need to create the tables store images manually.
Hi James , thanks for your response, I have a EGDB in ora 12 The feature service is hosted in portal 10.6.
Hi Pamela,
James Tedrick , Thank's for your help.I needed to have a field named "parentglobalid" and that is of the GUID data type
