Permission Issues in Survey123
1066
12-04-2019 10:18 AM
AnthonyWhitley
In my current survey and as an owner I of course can edit my data. However, I am having issues setting up other individuals with the same permissions (to edit data)
Pic 1: Owner - can edit
Owner can edit
Pic 2: User - with 'GIS User' permissions in AGOL - cannot edit
User with
In 'Collaborate' I have the following setup:
Who Can submit: Everyone
   Groups:  City of Fayetteville Public Works Content
                  City of Fayetteville Public Works Core Team
Submiters can: Add and Update
Is there something I am overlooking to allow other users to be able to Edit the data within Survey 123?
AnthonyWhitley
So after continued reading here it appears that only the 'Owner' can update Survey data from the back-end. Can someone confirm that this is still the case?
Thanks!
JamesTedrick
Esri Esteemed Contributor
Hi Anthony,
The owner of the survey can update all data via the Survey123 website.  A submitter who has also been shared viewing abilities will be able to update their submissions via the Survey123 website; please refer to the table at Share survey results—Survey123 for ArcGIS | Documentation .
You can also create an editing application using one of the many configurable app templates in ArcGIS Online if you need a more comprehensive editing solution - see Choose a configurable app—ArcGIS Online Help | Documentation and Web App Builder's Edit widget—Web AppBuilder for ArcGIS | Documentation
