Passing values via submission URL from Collector vs. Webmap
967
07-18-2018 01:08 PM
by Anonymous User
Not applicable
Hello all,
The background for this post is that I have a webmap containing a polygon layer whose pop-up has a submission URL hyperlinked to Survey123.  It appears that the issue is that any value from a domain which contains a space in the domain Description does not pass/match-up with a select multiple box label value in Survey123, when sent from Collector.  If I click the pop-up submission URL from within a web map in an AGOL map viewer, it launches Survey123 with the values populated.
I've tested the Collector to Survey123 workflow on an iPad mini 4 and on an Android Galaxy S7 where the values were not passed.
I've tested the AGOL map viewer to Survey123 on Windows 10 Chrome, iPad mini 4 Safari, and the Galaxy S7 Chrome.
Has anyone seen this?  I've searched submission urls and not found any related issues.  I'm thinking that replacing the spaces with underscores in the Domain Code Description would be a workaround and will test that after the users do some UAT.
Thanks in advance for any help!
Jim
JohnathanHasthorpe
Hi Jim
Having spaces in choices name values is not supported for select multiple questions.
This is dictated by the XLSForm specification.
So underscores in the name should work.
Thanks
John
by Anonymous User
Not applicable
Hey John,
Thanks for responding.  For clarity, I have underscores in the name field and spaces only in the label field on the choices tab.  Below is the portion of the submission url that is in question.
&field:business_name={Business_Name}&field:block_name={Block_Name}&field:temperature={Temperature}&field:cloud_cover={CloudCover}&field:wind={Wind}&field:precipitation={Precipitation}
If I understand correctly, the values being matched up here are the feature class domain Description and the Survey's choice Label, correct?
Again, all works fine when launching from a browser instead of Collector.
Thanks again!
Jim
JohnathanHasthorpe
Hi Jim
Yes, the domain description and the survey's choice Labels are being matched.
Sorry, I misunderstood you. As you say, spaces in the labels of choice lists are supported. This looks to be a bug with Collector as it is not handling the space in the URL correctly. Could you raise this as a bug with support, so we can attach a customer to it?
Thanks
John
JamesTedrick
Esri Esteemed Contributor
Can you test if a %20 works in place of the space? It sounds like we may want to ask for a urlencode function in arcade.
James
deleted-user-6vXX_OrqJjm0
I'm getting the same error when passing a domain coded value over through the submission URL to Survey123. Works fine via the AGOL web map but when through collector, it comes into Survey123 with a line through it.
