Passing value from main form to url
943
07-03-2019 02:59 PM
OussamaMerhi
New Contributor II
 am trying to pass a parameter form  the main form to another form as link. it works well when you set a value
concat('<a href="arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province=Basrah">237 Daily
Report</a>')
Now I want to replace Basrah with the value entered in the main form
concat('<a href="arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province={Province}">237 Daily Report</a>')
The proble it fills in province a text {Province} without getting the value in {Province}
Find attached the excel sheet
Tags (1)
EmmaDuncan1
Oussama Merhi‌ I have done this recently (with the help of a fantastic blog https://community.esri.com/groups/survey123/blog/2018/06/08/html-links-for-survey123-to-just-about-a...)
I did it in a two step process as suggested in the blog, first create the URL, then create the http hyperlink
concat("arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province=",${Province})
concat('<a href="',${Survey123URL},'">237 Daily Report</a>')
Once tested and working I made the first field type hidden
You can parse more than one parameter quite easily with this method, for example
concat("arcgis-survey123://?itemID=ec998f5e1d984bc5bb139c6e85040e7f&field:province=",${Province},"&field:village=",${Village})
