pass values from a related table in AGOL into survey 123?
364
11-10-2018 08:27 AM
by Anonymous User
Not applicable
how can i pass values from a related table of a feature class in AGOL into survey 123? I can pass values from the feature class to Survey123, but i am having trouble getting the data from the related table. i use the same syntax in my hyperlink:
arcgis-survey123://?itemID=a<suveyID>&field:FC_Field1={FC_Field1}&field:FC_Field2={FC_Field2}&field:RT_Field1={RT_Field1}&field:RT_Field2={RT_Field2}
FC = FeatureClass
RT = RelatedTable
JamesTedrick
Esri Esteemed Contributor
Hi Dan,
I believe that https://community.esri.com/thread/196867-get-related-objects-in-arcade#comment-695549  can address what you are trying to do.
