Parsing Error in Survey 123
820
07-19-2023 05:07 AM
MosesMukira
Hi, I have currently been trying to upload a report template to download reports from a completed survey off of survey 123. This error message has been displayed: An error occurred when checking the report template. Failed to parse ${sd_pdrpro_fu_choice | getValue:""} since sd_pdrpro_fu_choice cannot be found in the current parsing scope.
I used the report form reference to ensure all syntax was in order. Kindly assist.
Katie_Clark
Do you have any repeats in your survey? Aside from just a simple typo in the field name, this is the most common cause for this error. Make sure you have the opening and closing tags for the survey in the correct places.
If you need further assistance with troubleshooting, sharing the survey and/or report template would be helpful.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
