Hi. I'm suddenly getting a Power Automate run failure on a "Send an email" flow. It's being caused by not answering an optional Time question:
The template language function 'formatDateTime' expects its first parameter to be of type string. The provided value is of type 'Null'.
I'm using a dynamic expression to reformat the returned value:
I'm hoping to not make this question required, but I can't think of a way to return a value other than Null for an unanswered Time question. Any suggestions? Thank you
I have absolutely NO experience with automated email services so most of that code is foreign to me, but couldn't you just set the default of the time your formatting (Start_Time?) to (now) or does that not return a string? Definitely following this one...
