Open a a specific record in survey123
986
04-18-2020 02:10 PM
OussamaMerhi
I am trying to open a specific record in survey123 using the below link and also pass the value of Location. It is opened withouth filling the Location field with the value Reviewed. The form is opened for the record without filling the Location field.
https://survey123.arcgis.com/share/ad2c63230b194867a3c8a16379b0c789?mode=edit&objectId=11&field:Loca...
IsmaelChivite
Esri Notable Contributor
Hi.  If you open a survey record in edit mode, the values shown in the form will be the ones from the record you are editing. The value you are passing to the Location field is simply been overwritten by the value in the record.  It is not possible to load an existing record AND also pass a value to an attribute.
As a side note, you may want to move away from using objectId values to load the record and switch to globalId. For more details see this post: https://community.esri.com/groups/survey123/blog/2020/02/19/upcoming-changes-to-survey123-web-forms-...
OussamaMerhi
Hi Ismael,
Is there any way to pass a value to an attribute for the editing record?
Best,
Oussama
IsmaelChivite
Hi Oussama. Not possible.
