Notes to show up under each individual photo
1447
01-19-2023 12:07 PM
JennaMorse
I am using Survey 123 to inspection reports in the field. I have the survey set up to allow photos to be added. I currently have a untitled multiline text box as the next field in the survey, to give me an opportunity to describe what we are focusing on in the photos. When I run my reports, the notes I took regarding the photos appear below the last photo. Is there a way to create a note for each individual photo, so there is less editing when I run my reports? I would like specific notes to align with specific photos without additional editing, if this is not too difficult to achieve. Thanks in advance!
Katie_Clark
MVP Alum
If you have your photo question within a repeat, and a text question after it for photo notes, anything entered will be associated with that specific photo.
I actually just made a report template with this functionality the other day. Since it's within a repeat, it will print out as many records as necessary (i.e. create new rows in the table within the word document template)
Hope that helps!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
MVP Alum
Hope that helps!
Best,
Katie
JoeRob_AWPM
Having a very similar issue but I think its rooted at the database level.
Im trying give the user the ability to add notes to the images. I have added the "image_notes" field to the attachment table, however, the attachment table is not showing up in the rest service. Therefore, I can't publish. Any assistance would be greatly appreciated.
