Not possible to use the decimal separator (",").
1503
8
09-28-2018 05:28 AM
CristianoGonçalves1
New Contributor II
In form created in Survey 123 Connect with decimal field, when accessed by a user by in a web browser, it is not possible to use the decimal separator (",").
Does anyone have any solutions to this problem?
LuisCalderon1
New Contributor II
Try "." (period) instead of comma.
Luis
(863) 675-5365
lcalderon@hendrypa.com<mailto:lcalderon@hendrypa.com>
CristianoGonçalves1
New Contributor II
already tried and did not work too. But if I write in a text file, copy and paste it in the form field, it accepts the comma.
JoeBorgione
Comma as a 'decimal' separator? That has me confused:
1,75 liters versus 1.75 liters : to me the former is a range between 1 and 75 liters where as  the latter tells me I have one and three quarter liters.
What are you trying to represent?
That should just about do it....
CristianoGonçalves1
New Contributor II
I am trying to represent decimal separator for money used in Brazil, for exemple R$ 2,50.
LuisCalderon1
New Contributor II
Latin-American & I believe Europe also.
Luis
(863) 675-5365
JoeBorgione
Most interesting!  Thanks for the explanation!
LuisCalderon1
New Contributor II
Sorry, don't know what else it could be.
If no solution found, contact ESRI Support directly.
Luis
(863) 675-5365
FranciscoAndrade1
https://community.esri.com/message/735109-re-how-to-format-display-of-calculated-result-in-survey123...
As per that post, it looks like that functionality is not possible. The post is from 12/08/2017.
