New numbering/unique ID for each row on summary report template
277
01-11-2022 12:29 AM
BenBlowers2
Hi all,
I am creating a very simple summary report for all my photos. I would like each row in the summary to have a new number, "1", "2", "3".. etc...
I cannot use objectid, as this numbering system is sequential and wont ever start at 1, 2, 3 etc.
Is it possible to have a new unique numbering system for summary rows within a report template?
Ben
DerrickWestoby
@BenBlowers2 wrote:
Hi all,
Ben
Agree with Katherine's post.
You could calculate the integer field with something like position(..) if you're using a repeat.  It will auto-increment based on the repeat record, but it will not watch out for duplicates (for example, if you have 12 entries and delete #8 and then add a new record, you'll have two #12s).
edit: actually, it looks like you can access the position of a record in a report now without having to store it as a field.
${#defects}
${$feature | getValue: "position"}
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereporttemplates.htm
Katherine_Clark
MVP Regular Contributor
Hi Ben,
I'm not familiar with a way to generate this automatically with the summary report, but one thing you could do is add an integer field/column to the feature layer and generate the numbers through a field calculation before generating your reports.
This support article on How To: Sort and create a sequentially ordered ID field in an attribute table in ArcGIS Pro might help to get you started.
Best,
Katherine
DerrickWestoby
@BenBlowers2 wrote:
Hi all,
Ben
${#defects}
