new instance of a survey after submitting it
500
05-27-2020 05:19 AM
CodraFrum1
I am trying to open a new instance of a current survey (created using Survey123 Connect) with a certain value for a field AFTER submitting the (currently, active, survey). I am using something like:
<a href='arcgis-survey123://?itemID=aa809b97afed4126aa07bee048564e44&field:STREET_NAME=${STREET_NAME}'>Continue the same street</a>
It works GREAT but within the currently open survey and I need to work AFTER SUBMITting the survey.
(like attaching to the Submit button the above command line)
I saw this option only on the Web version of the Survey123, not the field app, Survey123 Connect!!!
I do appreciate any help since I spend 2 days in searching for a solution,
Codra
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Codra,
Apologies for the delay in response.  The field app does not have an after-submittal screen; it instead returns the user to the form page where another collection can begin.  One way to save the street name and use it for a template would be for the user to partially fill out a survey with the street name, mark the form as a favorite and save to drafts.  Subsequently, the favorite values could be filled in
