Número de repeticiones en función de una pregunta anterior.
1021
05-04-2019 11:53 PM
Fco_JavierRomero
Estaba busxando la posibilad de limitar el número de repeticiones en función de una pregunta, p.e. vamos a tomar datos de los cultivos existentes dentro de una parcela, los distintos cultivos son las repeticiones y son conocidos al comenzar la encuesta, de forma que habría una pregunta "No. Cultivos', y segun está cantidad aparecerían tantas repeticiones.
by Anonymous User
Not applicable
Hi Javier,
Based on rough translation, your question is as follows:
I was looking for the possibility of limiting the number of repetitions based on a question, e.g. we are going to take data of the existing crops within a plot, the different crops are the repetitions and they are known at the beginning of the survey, so that there would be a question "No. Crops', and according to this amount so many repetitions would appear.
Yes, this is possible using the repeat_count column on the begin repeat question in the xlsx file. The value used can either be static (enter a set number like 5) or use a calculation so that the number is based on the answer or calculated answer to a previous questions or lookup data.
More info about repeat count can be found here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformrepeats.htm#ESRI_SECTION1_1FC4AD92...
Hope this helps.
Phil.
Fco_JavierRomero
Thank for all
Is that right¡
