Multiple Tablets submitting parts of a single survey
354
03-18-2024 05:37 AM
Reuben
hi,
Using multiple tablets to collect and submit sections of a single survey is workable in ArcGIS Survey 123 or not?
There's a way to do that in Fulcrum Field App. I'm new to ArcGIS Survey. Any suggestion would be greatly appreciated.
jcarlson
MVP Esteemed Contributor
How do you mean? Would this be a single user switching devices, or multiple users dividing up the survey?
There are lots of ways to collaborate and work on the same data in Survey123, but which route you go really depends on what you need the process to accomplish and how you want it to function.
You could have the different sections as entirely separate forms, which you could edit through the field app's Inbox.
- Josh Carlson
Kendall County GIS
Reuben
Both, either single User switching devices or Multiple Users.  I tried both Single User switching devices and multiple Users but ended up loosing parts of my survey inputs.  Further suggestion would be appreciated.
jcarlson
Does the device / user switch happen at defined points? I think using multiple forms for the different sections could be a workable solution.
- Josh Carlson
Kendall County GIS
