Multiple radio buttons for select one questions
2238
07-19-2021 12:16 PM
christinesmith602
When publishing a survey using Survey123 Connect Version 3.12.232 the radio buttons on select one questions appear twice (side by side) the righthand bubble is auto selected. The survey functions fine... ie if you click the left button it behaves as expected.
The survey looks fine when previewed in Survey123 Connect.
I've tried the beta version 3.13 and have the same issue.
JodyZhengLiu
Hi @christinesmith602 ,
When was the survey published? If it was published before March 9, you need to republish it to make the choices UI working. Also, could you please confirm that in the Settings - Services - Survey123 REST API URL in Connect, it is using https://survey123.arcgis.com/api ?
Jody Zheng Liu
christinesmith602
Good Morning @JodyZhengLiu
Thanks for the response. It is a new survey I'm attempting to publish. That is the service we are using (screenshot attached).
Christine
j-bromp
I am also having the same issue, 3 years later.. Any updates on this?
