Migration of Survey123 form between Dev, Test and Production.
529
04-08-2020 07:34 AM
AdamBranscomb1
We need to migrate Survey123 configuration from dev to test to production. In production, the only people who have configuration access don't know how to use ArcGIS, so it needs to be fully scripted.
Has anyone done this before, are you able to advise how to do this?
JamesTedrick
Esri Esteemed Contributor
Hi Adam,
There are a few different workflows available.  The easiest is to simply maintain Dev/Stage/Prod copies of the survey and use Survey123 Connect or the Survey123 Web Designer to publish to the appropriate environment as changes are made - this does not require knowledge of ArcGIS Online, just the Survey123 Connect application.
