Maximum file size in Survey123 Connect for ArcGIS media folder.
1633
06-20-2017 07:01 AM
AlexCarrier
Is there a maximum file size that I can place in the media folder of my survey using Survey123 Connect for ArcGIS? I am trying to copy a .tpk I made into this folder and it says there is not enough room in the folder, even though there is nothing currently in it.
JamesTedrick
Esri Esteemed Contributor
Hi Alex,
If you're getting a message about space at file system level, you should check the amount of free space on the hard disk - most likely there isn't enough room on the drive.
In terms of uploading TPK files, I'd refer to What can you add to ArcGIS Online?—ArcGIS Online Help | ArcGIS .  While Survey123Connect isn't a web browser and can publish a larger file, for most practical purposes 1GB is a reasonable upper limit when you consider that your devices will need to *download* the data as well as any constraints uploading.
