Map not centering on the geopoint and missing marker while Printing Current Response
1011
06-13-2017 12:33 PM
KevinBrown10
When utilizing the "Print Current Response" feature from within the Survey123 for ArcGIS website, is there a control so that the map shown on the output will automatically center on the geopoint?  Currently most but not all center over San Francisco even though the geopoints and home location are in Michigan.
Also, when printing to PDF or to an actual printer, the marker for the Geopoint disappears.  Any help in making the marker appear in the output would be appreciated.
Kevin
by Anonymous User
Not applicable
Hi Kevin,
For the map scale/zoom applied to the Print Current Response map, this can be set in Survey123 Connect before publishing your survey. By setting the Zoom level in the Settings -> Map -> Detailed Map section, the zoom level will be honored on the Survey123 website when using the Print Current Response option.
With the issue of the missing marker on the Print Current Response map, what internet browser version are you using? Have you tried printing the current response from a different browser or computer, if so did it work?
Regards,
Phil.
