Make points to disappear after period of time
275
09-12-2022 11:29 PM
giladuzann
hallo
I created a survey using survey123 connect.
the survey shows points of garbage in the forest that workers can point id they spot a place were there is alot of garbage.
after a while the map shows allot of points... too many..
Is there a possibility to make the points disappear (after 2 days) without delete the points, so what the data will not be deleted?
thanks!
jcarlson
MVP Esteemed Contributor
You could base the symbology on an expression like DateDiff(Now(), $feature.date_created, 'days') < 2, then adjust the points to make the older points transparent.
Can you please elaborate where your users are seeing the map? Is this the map in Survey123?
- Josh Carlson
Kendall County GIS
