Lost default, When check an uncheck in Survey123
897
03-31-2017 09:03 AM
Steven_OswaldoOrtiz
I make a survey with Survey123 Connect for ArcGIS V 1.10.43 , using default values, the questions have the opcion to on or off, but I on again, the default value is lost
Someone knows what happens and how to solve it
I attach the file if someone can review it the item is "Seleccione el tipo de revision"
Thanks.
JamesTedrick
Esri Esteemed Contributor
Hi Steven,
When a question is 'off', it is considered not relevant to the survey- the value is emptied out as submitting the value could be considered erroneous.  Literally, the question should not have been asked, therefore a value should not be submitted.
We will have the capability to minimize groups of questions in the display in version 2.0 (currently in open Beta - see Survey123 for ArcGIS v 2.0 (Beta Available) ) if that's what you need for your survey form.
Steven_OswaldoOrtiz
Thanks James, I Hope the new version 2.0
