Login to ArcGIS online using a profile keeps asking to delete profile since it is v1.3 format
1252
03-24-2020 07:28 PM
MaazaMekuria
I am wondering why from time to time that the login into ArcGIS using a profile keeps asking to delete it since it "appears to be in the <v1.3 format....  . This is not nice, I did not ask it to be v1.3.  Infact when the profile script is run, it says it is version 7.4!  I upgraded to 1.8 and now I turned back to 1.6.2 . What is wrong here?
Please see the image below and help me figure out what version it is talking about.  The API version 1.6+ the ArcPro installed is 2.4.3 and I have updated python 3.6 (it is the compatible version for ArcPro) .
I use a script to set the profile as detailed in using authenticated profiles. Working with different authentication schemes | ArcGIS for Developers
Why is this error coming up?
JamesTedrick
Esri Esteemed Contributor
Hi Maaza,
It looks like this might be better asked in ArcGIS Pro‌?
JadeWeideman
New Contributor II
Hi James Tedrick, I don't think this has anything to do with ArcGIS Pro. I am experiencing the same issue.
Our client only has ArcGIS Online, no ArcGIS Pro or access to ArcPy (only ArcGIS API for Python) and long story short, I wrote a Python script that does basic ETL processes (gets data from their API, transforms and loads it into a Hosted Feature Layer in their AGOL account). I followed the approach here to set up a .arcgisprofile persisted profile for saving the credentials to their AGOL account on the local machine in windows credentials manager:
  • To create the profile using Python (once off):
gis = GIS(url="https://arcgis.com", username="something", password="something", profile="AGOL_prof"')
  • For the script to use the profile from then on onwards:
gis = GIS(profile="AGOL_prof")
It worked fine for a few weeks, the python script was scheduled and the layer in AGOL was updated regularly with new data like it should.
After a windows update one night, we realised the layer wasn't being updated anymore and I saw this when I tried to run the script using Command Prompt:
I had to delete the profile and create it again. It worked for a day and then the same thing happened again.
Hope this helps
Jade
JamesTedrick
In that case, it sounds like it would be better asked in ArcGIS API for Python‌ - this was originally posted in the Survey123 group.
JadeWeideman
New Contributor II
