While doing field testing on a survey on Friday, I was having an issue with Survey123 logging me out while I was filling out my survey. When I went to submit a survey, it brought me to the log in page, and once I logged in it submitted the survey as usual. It happened whenever a survey took a little longer to fill out, say ten minutes, and I was using an enterprise account if that makes a difference.
This isn't a huge deal since it doesn't seem to effect the submitting of the data, but is there a way to prevent survey123 from logging out, especially while it's in use?
Hi Philip,
Please provide the following...
Which version of Survey123 are you using?
What are the details related to the Enterprise environment?
What are the details of the device encountering the behavior?
Thanks for responding Brandon.
The issue occurred on both Samsung Galaxy Tab E's and iPhone X's, all of which had the latest updates of Survey123 according to the tech who prepared them.
I am not sure how to give more details on the Enterprise environment. When prompted to log in again, we would choose Enterprise Login, and then once we typed in the Enterprise URL we were logged back in - i.e. we did not have to type in individual usernames and passwords to get logged back in. This may be related to default user settings and not the issue at hand, however.
Please check the installed version of the Survey123 field app by starting the app, clicking on the hamburger menu in the top right corner and selecting 'About'.
Thank you,
Brandon
Brandon, the version is 3.2.265
Are you using IWA authentication with your Portal?
Timmons Group's ArcGIS Online is using SAML 2.0 to authenticate with our Active Directory.
Hi Philip,
Have you tested with the latest beta version 3.3 available on EAC, we will be releasing this version by the end of the month and there are some fixes for IWA and portal logins: Welcome to our Feedback Community
Phil.
Thanks Phil! We'll give that a try and see if it works
I might be having this problem also. I just updated to the new version of Survey123 Connect, 3.2.196. I've got a survey with 30 lines in the XLSForm. After I've published it and tried a test submission via the URL, I get a "Failed to submit. - GWM_0003:Token Required" error message. Then I refresh the URL and it takes me to the AGOL login page.
