Linking Survey123 survey to Offline Field Map
381
10-16-2024 06:50 AM
ElyYancey
I am trying to use the ESRI Roadway Management solution to conduct a pavement condition index survey. I was able to download the PCI Field Map as an offline map, and I was able to download the Survey123 form for offline use. However, when I go offline and try to launch  the Survey from the integrated link, I get an error because of no internet access. Is there a way to fix this so I can do everything offline?
DougBrowning
It should work fine.  Post a copy of your URL and how you are adding it to the popup.
ElyYancey
I am using the standard PCI Field Map from ESRI Roadway Management solutions, so I didn't put the URL in there or set anything up myself. But this is what the default Arcade function is using:
DougBrowning
You don't need Arcade just make it a text hyperlink.  Works better that way.  You would need to swap out the item id above for your version of the form of course.
ChristopherCounsell
MVP Regular Contributor
Try:
arcgis-survey123://?itemID=eb9aa31eece140508d770a2d3d1d7816
The link you have directs me to a web page prompt to download the app or open the survey directly. I've already got the app installed so don't want to get this page.
If the users don't have the app installed, well they're offline so that'll be an issue anyway.
