Lines and Polygons
5023
20
04-04-2017 12:01 PM
JimmieAustin
Does survey123 have the capabilities to capture lines and polygons? Instead of just point features associated with the survey.
JimmieAustin
We also have R1 units that can be synced with a mobile device that allows for sub meter accuracy.
by Anonymous User
Not applicable
Sure, Collector has the High Accuracy GPS metadata capture, but so does Survey123, but the data entry is cumbersome at times and I like to have my data per-processed before I take a look at it within the GIS.
However, if you apply this read and if you set up your data schema the correct way while building a few tools, then you can have all of the lines and polygon data gathering Survey123 forms you want.... https://community.esri.com/groups/survey123/blog/2017/05/31/blog-high-accuracy-gps-data-collection-o...
We use an external GPS unit; non-Trimble, that allows us to grab data down to 6 inches and then we also have RTK capabilities if needed all within Survey123.
Don't get me wrong, Collector has a place for us in our lineup of tools that we utilize, but sometimes; well most of the time, it pays to think outside of the box!
Cheers!
JoshJones9
Were polygons and lines ever supported? I do not currently have access to my iPad and I need to figure out if Survey123 will work for our field staff.
Thanks!
BrandonArmstrong
Hi Josh,
Polygons and lines are not currently supported with Survey123, however, they will be supported in the future.
smukahhal
Do you have a estimated date of when that will happen ?
JohnathanHasthorpe
Polyline and polygon support is now available in beta. Please go to the EAC site to start testing!: Welcome to our Feedback Community
Joseph_Kinyon
Occasional Contributor II
I saw that in my email first thing this morning, so excited to test!
Thanks Survey123 team, another major milestone is about to be reached.
by Anonymous User
Not applicable
Thank you very much for the work, I look so much forward to test it.
NathanDulfon
I have tested the Beta version.... It is great...
Is there the option within the polygon function to add just a point?
when is the polygon function going to be available in the regular S123 version....???
I would love to use this next field season....
Nice work ESRI folks!!
by Anonymous User
Not applicable
Hi Nathan,
Hopefully my answer on this post answers your question here: https://community.esri.com/message/837522-re-when-will-survey123-support-polylines-and-polygons?comm...
Phil.
