Likert data discrepancy in export
106
08-21-2018 04:21 PM
Moderator
I created my survey in the Survey123 web app. When I export my data from the data tab into Excel I am seeing that the data changes for one of my questions and does not reflect the respondents answer.
The question type is Likert with a scale of 1-10 as the options to choose. In my Data tab online i can see when people have chosen 10. When I download this data as an xls this answer is being displayed as choice9 and not choice10 to reflect what I can see in the online response.
Is this an issue with how the likert question has been configured in the survey?
Community Moderator, Esri Community Team.
Reply
Esri Esteemed Contributor
Hi Louise,
Single-choice questions like likert use a coded value lookup that separates the value stored from the value shown.  In this case, the values stored are most likely choice0, choice1, choice2, etc. - if you have a 1-10 scale, the corresponding choice would be choice9 (0-9 vs 1-10).  This is configurable when publishing a survey on the website via the 'Manage Schema' link - that enables customization of field names and choice values.
Hi Louise,
Moderator
Thanks James that makes sense and I'll definitely modify the schema for future surveys to adjust that field value to match the answer when using 1-10 scale.
Reply
