What's the minimum license requirements that would allow me to to create survey I can distribute to up to around 250 contributors who are not necessarily in the same organisation as me?
Hey @agriben
In order to just create the survey, you will need a Creator license, those filling out the surveys I believe may need a Field Worker or Mobile Worker licenses at minimum to fill them out, here is a link showing how to get out of organization users access: https://community.esri.com/t5/arcgis-survey123-questions/how-can-a-survey123-form-be-licensed-to-all...
Cody
The survey could be shared with everybody and you could send links to the survey to intended recipients.
https://doc.arcgis.com/en/survey123/browser/analyze-results/sharesurvey.htm
No license required for them to fill out the survey via the web link.
