Labor Cost for a Job Site
606
02-04-2020 12:06 PM
RobinKloepfer
I am using Survery123 Connect and trying to return the labor cost for a job site. I am having a hard time trying to get the employee's name to match their hourly rate. It seems simple in nature, but not in Survery123. In Excel, I can do it with a few different formulae to have the employee name and/or title match their hourly rate. That would then be multiplied by hours worked. It's just not clicking in Survey for me.
BenTurrell
Hey Robin Kloepfer‌,
I've just had a look at your calculations and it looks correct. Your employee field seems to be a select field and you seem to be checking if the name is senior. Is that correct or does your employee field contain employee names?
Ben
If this answer has helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
RobinKloepfer
The field has ‘senior’ and then the employee name. I was hoping that it would find anything in the field and not the exact.
Thank you,
Robin Kloepfer
Management Analyst II
City of Tracy
Department of Public Works
520 S. Tracy Blvd
Tracy, CA 95376
209-831-6366
BenTurrell
Robin Kloepfer‌,
You could try using contains():
if(contains('senior',selected(${employee})),'57.44',.......
Let me know if that works.
Ben
