Label hyperlink using pulldata not working in web form
655
02-11-2021 09:29 AM
pskrivanos
New Contributor II
Hello,
I've just created a survey using Survey123 Connect and have published it. In my survey I have created a label which includes a hyperlink. This hyperlink is being pulled from a csv file using the pulldata function.
Here is my label with the hyperlink: Click <a href="${reference}" target="_blank">here</a> for an identification guide
This link works perfectly fine in the app, but not in the web form. In the web form is looks like this:
Click " target="_blank">here for an identification guide
Any ideas on why the web form link does not work but the app link does?
Jing_Sun
Hi, hyperlink does work differently in the web app, and I normally use the concat() function for building hyperlink in the web form.
If you don't mind using a note question to display the hyperlink, below is an example that works for both field and web apps. Given that concat() does not work in label, I put it in the calculation and use a placeholder for the label. You might also find the calculation looks wrong in the app if ${reference} is empty, hence I give ${reference} a default value.
Jing_Sun
pskrivanos
New Contributor II
Hello, and thank you for your response. Your suggestion works, and I'm very pleased with the outcome.
