Item specified by surveyItemId does not exist or is not accessible
12025
39
10-18-2020 02:25 PM
MattCreaney
Hi all,,
I have multiple feature report templates on a particular feature layer and these have all been working great - until Friday, when they all stopped working with the error:
To my knowledge there has been no change to the feature layer, there has definitely been no change to the report templates and the survey, whilst it has been republished recently, has only had items added, no items removed or changed.
What's the problem here?
Ismael ChiviteJames Tedrick‌ your help would be much appreciated here, our organisation can only bill the customer upon receiving said feature reports..
Ruth_JiatengXu
Hi Mattew and Yulia,
Matthew AdamYulia Mamonova
The fix of "An error occurred when preparing." is already on the production website. Thanks a lot for the support!
Ruth
AmyStorey
We are having the same issue as well.
AmyStorey
Our issue is resolved in the BETA site
Ruth_JiatengXu
Hi all,
The fix is now available on the production website. However, if you have a very long external choice list in your survey, you may still encounter the "An error occurred when preparing" error, which will be fixed in 3.11 hotfix2.
Ruth
YuliaMamonova
Hi Ruth,
It's been over 2 weeks since our survey has stopped working. Now the error I am getting is TypeError: Failed to fetch.
YuliaMamonova
I've just checked - everything works OK in survey123 beta, when can we expect it to be OK in survey123 production site?
Ruth_JiatengXu
Hi all,
Survey123 hotfix2 is on production right now, the report generation failure with the error "An error occurred when preparing" is fixed.
Thanks.
Ruth
HubertGimpl1
Hi Ruth, it seems that the same issue occurs again - are you aware of that?
SimoneLuppi
I have the same error "Item specified by surveyItemId does not exist or is not accessible" when I tried to manage a template to carry out a report.
The error affects only the last Feature layer (SURVEY123 form). The others still work.
SimoneLuppi
I fond out that in my case,
  • the issue is caused by using a select_one_from_file and the csv name contains brackets, e.g. “select_one_from_file italy_(2024)_specie_brc.csv”.
  • After publishing the survey (which works regularly), if I use  SURVEY123 connect v.3.22.49 (the last one) I was not able to open the Survey123 website successfully (see attached file), if I use SURVEY123 connect v.3.21.62 (the previous one) I can open the survey on Survey123 web app, but when I tried to apply a template to create a report, the web platform gives the error "Item specified by surveyItemId does not exist or is not accessible".
So, skipping brackets from the name of .CSV file, the error disappears.
